Help 5 Codes!!!!!!!
Old Dec 11, 2008 | 09:29 PM
Redliner's Avatar
Help 5 Codes!!!!!!!
ITS RAINING ITS BUTT OFF HERE AND DRIVING HOME LATE FROM THE SHOP ALL THE GAUGES QUIT WORKING, ALL THE DASH LIGHTS COME ON AND NO BUS IS ON THE ODOMETER. CHECKED CODES WITH SMARTY AND GOT:
1698 NO CCD/J1850 MESSAGE FROM TCM/PCM
1693 DTC DETECTED IN COMPANION JTEC MODULE
1687 NO CLUSTER - BUS MESSAGE
1694 MESSAGE ECM - NO BUS
0500 NO VEHICLE SPEED SENSOR SIGNAL
WHAT THE HECK HAPPENED??????????
PLEASE HELP.... TRUCK STILL STARTS AND RUNS BUT AM KINDA SCARED ON DRIVING IT.
Old Dec 12, 2008 | 03:31 AM
Adaminak's Avatar
Just a quick guess (don't have access to my manual right now) would say you splashed a good bit of water into an electrical connecter, probably right above the driver's front tire wheel well liner, and it caused your connections to short out. If the truck still runs fine, drive it and they'll probably go away on their own. When you get time, pull the connections apart under the ECM, clean, coat with dielectric grease, and put back together.
Old Dec 12, 2008 | 06:35 AM
Redliner's Avatar
Ok so which connectors do i need to check for. The ecm on side of block was dry when I looked at it so where do I need to go??????????
Old Dec 12, 2008 | 10:22 AM
infidel's Avatar
Hard to tell by just looking, engine heat will dry the outside but the inside where the connectors are will still be wet.
Old Dec 12, 2008 | 11:11 AM
Redliner's Avatar
ok ill do that tonight. thanks
Old Dec 13, 2008 | 09:45 AM
Adaminak's Avatar
Another place to check is the main power distribution box right above the wheel well. You probably won't be able to see anything by simply removing the cover, but if I recall correctly, the whole module will lift up after removing just two screws, and you'll be able to tell if the connections are wet. It could also be one of the big connections that run from the distribution box along the steering column into the back of the dash.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
StormTrooper
Mar 28, 2005 09:17 AM
