help
Old Feb 28, 2009 | 09:03 AM
Jacob wiley's Avatar
help
2002 cummins wont start it just turns over. On dash it says p pcu and p ecu
Any help would be great thanks.
Old Feb 28, 2009 | 09:51 AM
Adaminak's Avatar
Did you recently do a fuel filter change or work on the injectors or fuel system?
Old Feb 28, 2009 | 10:13 AM
Just put a new lift pump on. I think they may be fuel codes how do you prime a 24 valve
Old Feb 28, 2009 | 10:30 AM
Wild4kst8's Avatar
crack an injector line & bump the starter... you will hear the LP running & fuel should start coming out the cracked injector... snug up injector & bump again... crank engine, engine will lope a bit until you fully tighten injector line
do you have fuel pressure gage?
Old Feb 28, 2009 | 01:56 PM
Thanks for the help guys. Parts store gave me the wrong pump. its fixed now thanks again.
kcredneck
Jul 25, 2007 10:11 PM
ollie32
Jun 6, 2007 09:21 AM
2500TurboDodge
Jul 31, 2006 04:21 PM
bkay
Nov 6, 2003 10:39 PM
