Help 1995 12V will not start
Old Jul 28, 2008 | 10:02 AM
wally5096's Avatar
I have been trying to get a friends truck started and it will not. He changed the lift pump and then messed with the DVs. After inspection he had a DV in upside down and ruined them. I had a set and put them in. I also, checked the solenoid which was junk and put another one on.
The truck now gets fuel to all of the injectors w/o any air in them. The truck will fire on ether but will not stay running. I have ran out of things to try. ps I have tried all of this with the truck plugged in.
Any ideas???
Thanks,
Jim
Old Jul 28, 2008 | 10:28 AM
John Faughn's Avatar
Is the Fuel shut off linkage lifting when key is turned to start position ?
If not then turn key to run position , lift linkage [ it should snap into the lifted position ] , then from the run position , turn to start , it should start now , if not you need to check the relay for the lift circuit on the heavy 70 amp relay .
ducati916rdr
Jun 19, 2012 09:41 PM
JIT
Jan 21, 2008 08:08 AM
strokerace
13
Nov 15, 2007 06:52 PM
Tacomaman87
Aug 9, 2007 07:57 AM
Sidewinder
Jan 6, 2004 05:12 AM
