help
Old Mar 11, 2008 | 07:04 PM
dragon_customs's Avatar
help
ok this is my dillema, my old boss has a 1994-1997 dodge ram with a cummins in it, its having a problem charging the batteries and it is also having a problem with the wait to start light fashing
Old Mar 11, 2008 | 09:00 PM
dozer12216's Avatar
Does the tach work? Some have a sensor on top of vib damper to allow charging. First step is generally pull alt and have it bench tested. On vehicle has been unreliable.
Old Mar 12, 2008 | 10:46 AM
actually the only gauge inside the truck that works is the speedo and the charging meter, but that could be because whoever put it together messed some stuff up, it is a 1990 cummins frame and engine, with a 1996 body on it
Old Mar 13, 2008 | 12:50 AM
Katmandu's Avatar
Arrow
That's correct. The sensor is the CRANKSHAFT speed sensor.
Not sure or not if a 90 Cummins engine has it. ???? Probably does.
Old Mar 24, 2008 | 12:30 PM
ok heres a correction to my first post it is a 1990 engine in a 1996 truck, the only gauges inside the truck that work are the speedo and the volt meter, and the wait to start light flshes is there ne one that can tell me how to get that to stop flashing and get the truck to charge
Old Mar 24, 2008 | 05:41 PM
patdaly's Avatar
Did you re-install the CPS and make sure it is working?
That is where I would start.
kcredneck
Jul 25, 2007 10:11 PM
ollie32
Jun 6, 2007 09:21 AM
2500TurboDodge
Jul 31, 2006 04:21 PM
bkay
Nov 6, 2003 10:39 PM
