Heating Problem
Old Dec 2, 2008 | 10:39 PM
bootsdodgejn's Avatar
Heating Problem
Ok well first off. I have my adrenaline to do warm-up to 145. It cut off at that temp. I was going down the road about 8 mins after it hit that. Look at my coolant level it was ranging from 145-165. Never went to 178 or any thing close to the range it should be. But when i get home i turn the high idle on and it went to 188. Any Ideas.
Old Dec 2, 2008 | 10:50 PM
BigIron70's Avatar
Cummins Guru
I would replace t-stat. If engine is not warming up to temp most likely it is bad.
Old Dec 2, 2008 | 10:52 PM
Do you think i could still use the truck. I need to tow a buddys car tommrow.
OR can it be replaced real easly.
Old Dec 2, 2008 | 11:33 PM
b4wheeler's Avatar
You can still run the truck if it does not get up to temp.. That is fine....
It also only takes about 10 - 20 minutes to change a thermostat.... 3 bolts off, new thermostat and gasket, 3 bolts on.......
Old Dec 2, 2008 | 11:39 PM
Hmm. Ill have to see if keen has one and get some coolant to, in the morning. Need to leave by 1145
Do you know how much it is
Old Dec 3, 2008 | 06:09 AM
scottsjeeprolet's Avatar
Get a thermostat, don't need coolant, it takes all of 5 minutes to change.
Your temp differences might be from the cold air, try a piece of cardboard between the rad and inter cooler.
Boots i see you have stopped using your spell check again!
Old Dec 3, 2008 | 06:23 AM
DIESELDENT's Avatar
i got my last one at pep boys they had them in stock and it was around $10. i had one fail when i was towing, it got realy hot very quick.
ImprezdGurl
Jan 18, 2020 04:59 PM
bigdaddyL
Mar 1, 2008 01:44 PM
rincon4939
13
Jan 31, 2008 06:48 AM
bigthumper
Mar 14, 2007 08:07 PM
fitzer
Aug 21, 2004 09:47 PM
