Headlights turning off while driving..
Old Dec 31, 2008 | 10:31 PM
ImprezdGurl's Avatar
When im driving my headlights will turn on and off on there own..then they will work fine for a while.. I dont have a clue what is causing this.....Thank you for the help..
Old Jan 1, 2009 | 09:37 AM
rich's Avatar
i cant remember what year model but i believe their was a tsb about the headlight switch i think but it also maybe a short some where
Old Jan 1, 2009 | 10:00 AM
scottsjeeprolet's Avatar
Mine did that and only the high beams would work. It was the purple wire in the steering column, it would come unplugged, check that wire. It was caused from tilting the steering wheel.
Old Jan 1, 2009 | 11:38 AM
93John's Avatar
I had a problem with the connector that plugged into the headlight switch. It got hot and melted part of it, it would come loose and make a bad connection when the truck it a bump.
Old Jan 1, 2009 | 12:00 PM
Thanks for all the info im gonna try the headlight switch first.. thanks Jason
Old Jan 1, 2009 | 11:53 PM
jnicewan's Avatar
my 98 did that, they would flash off/on at random times, and worse the longer they were on. the switch has a built in circuit breaker that can become weak causing the breaker to open/close. i replaced my switch. the connectors-pins were ok and the problem is gone now
Old Jan 2, 2009 | 06:30 AM
So far the switch did the trick but I haven't drove it at night very far yet..so I hope that was all it was...Thanks for all off the help.....
Reapertura
Apr 1, 2012 07:00 PM
510rcr
Oct 31, 2009 03:30 AM
lightening ram
Jan 20, 2005 11:36 AM
Rocketman
Oct 25, 2004 10:04 PM
