headlight delay!!
headlight delay!!
couple of years ago i disconnected the "daytime" running lights module...i just didnt like it....so ever since ive been turning lights on manually...one pull for the clearance lights and the 2nd pull for the headlights....familiar?......anyhowthis year since it started to get cold...i'll turn on the motor....one pull...and the clearance lights come on...2nd pull and nothing comes on...when the truck warms up a bit 3-4 min they flick on....whats going on??....where is my bad contact?
Andrew
Andrew
Try giving the dimmer switch a good shake while the problem is occurring, and switch high to low beam several times. It's quite common for the multifunction switch to fail this way, but it usually happens while you are operating the switch- the lights will go out instead of dimming.
Other than that, the next place to look is the headlight switch. They are cheap enough that you might as well throw a new one at it, and have a good look at the connector for signs of overheating.
By the way, is your headlight wiring stock? You haven't installed a relay kit or anything?
thanx torquefan...yeah the wiring and switch is all stock factory..i took the switch out...d/c the wiring to it...sprayed contact cleaner into every crack i could find and tried working it in by pulling the the switch **** out and in....cleaned the connectors...put it all back together and lights turned on first pull...niice...lets hope it stays that way
mtdoragary
Nov 7, 2013 08:31 AM
jlipskoc
Oct 24, 2005 01:16 PM
Jack Thorpe
Nov 6, 2003 01:25 PM
