head stud broke off in block
Old Aug 27, 2005 | 03:10 PM
mhuppertz's Avatar
Drill enough of a hole to get an easyout in the stud, heat the block around the stud with a rosebud, then carefully dribble some liquid nitrogen in the hole you drilled. Then put the easyout in and it should come loose. You can get liquid nitrogen from a welder supply, they will put some in a stainless thermos for you.
Old Sep 10, 2005 | 03:18 PM
werewolf's Avatar
the story continues, we took the truck to a big rig mechanic...they are just now getting to it. sent it off to a welder with special tools, sounds scary. we now need more studs anybody know a shortcut to who has them? another question who on earth needs a 12v with fire rings for a daily driver? do any of you guys know anyone who has done this just curious guess the previous owner had lots of money.
Old Sep 11, 2005 | 09:10 AM
mhuppertz's Avatar
Big turbo pressures are the only reason to o-ring the head. From what I hear pressures over 40psi are getting into o-ring territory. On the HEMI race cars the gasket and copper wire had to be put in just right or she'd leak.
I know a guy who spit the head gasket at 50psi on a standard head/block.
Old Sep 11, 2005 | 09:49 AM
Blue3500's Avatar
Fire Rings
Generally you wouldn't have to worry about something like this unless you're running a bigger turbo, but even the HX35 will put out higher turbo pressures with some of the chips/programmers out now. In the older 12V boosting over about 40 psi is a bad thing and it needs to be done. Sounds like you got hold of a truck/engine that somebody was running a little harder.
Old Sep 12, 2005 | 09:14 AM
werewolf's Avatar
indeed, had we known we would not have bought it. this is something we didn't bargain for.my son who had to have this thing traded a perfectly good powerjoke that is still running with over 200k <and having been rode hard and put up wet by both my monsters>whil this reliable ,haha,12v is parked for going on 7 weeks. now my new dilemma do we just pust back head bolts we cannot afford new gasket with rings,2nd since the guys put the new one on with out finding out not to first these things are 273 bucks, new head studs are 450 bucks . i am going to sue the previous owner for non disclosure...seriously folks this isn't something you can look at and tell these mods have been done. oh and by the way the guy who did the engine screw up is now in ok BEWARE i will soon post a wanted poster for him what are these pwople thinking?
Old Sep 12, 2005 | 09:19 PM
Stamey's Avatar
Talking
Yep, I know a few guys on here that did it to their "daily" drivers. That daily driver sure can go though!
As far as boost goes, I feel good about doing as much as 70 psi with my stock head gasket, and have done it. I try to keep it down to about 60 most of the time though.
Since it has gone to the machine shop now, I won't bother with advice on the stud removal.
Chris
Old Sep 13, 2005 | 01:17 PM
werewolf's Avatar
help again it appears that there is only one place in the world that makes head gaskets for fire or c-ring set up and though haisleys is great they are awol at the moment and that is not good for us good for them ,pulling or racing or whatever,we are stuck without truck for two months now....i think i will buy something nobody wants to jack up,hop up, or do any mods to,safer that way. really need any suggestions asap helllllpppp
Old Sep 13, 2005 | 01:26 PM
mhuppertz's Avatar
I think you can use a regular head gasket with a copper wire placed in the channel. Just make sure that the wire is heavy enough gauge to squish down and seal, and not so heavy that it does not allow proper clamping on the gasket. Measure the slot and I will find out the correct wire gauge for you if you want.
Mark
Old Sep 13, 2005 | 03:02 PM
werewolf's Avatar
we are pretty sure that you can reuse the orings we have but we ,my husband, put the gasket on and torqued down without the head being redecked so we now must get a gasket, which is water jetted out for the rings. so ?
Old Sep 15, 2005 | 12:33 PM
jimk's Avatar
Originally Posted by high country
if you can dent it with a center punch you can drill it, and you will need to center punch it in the middle, if you miss center by much grind it and start over, as rcw said heat it up, I would use oxy-acet on the stud only as it will heat in a few seconds and the block will just dissapate the heat, then while it is still hot drill your center punch mark with a left hand drill bit if you can find one. it screwd in its gotta screw out
If you could get a mag base drill that could help. good luck Jim
Old Sep 16, 2005 | 03:59 AM
Joe Mc's Avatar
That stinks! I, like some that have alread mentioned, have had great success with welding something that will help you grab whats broken off below the surface. Only different thing I've done is weld the hole of a thick washer to the surface of the bolt and then weld the outside edge of the bolt to the washer. While everything is still nice and hot from welding shoot some penetrating oil towards the studd as much as possible to shrink it a bit and then hit it with an impact. Go slowly with short bursts and if noting happens try tightening, loosening, tightening, loosening and once it starts to free up don't stop. You may break off the welded washer and nut a few times but, take your time keep a cool head and don't give up. If possible, not sure with the O ring machining that's taken place, I'd re-install new factory bolts.
thechoochlyman
Jan 2, 2013 05:54 PM
lostcreek21
Mar 1, 2010 06:13 PM
hic316
38
Jan 12, 2008 10:03 PM
74dart
Jul 7, 2007 07:58 PM
Zackb911
13
Jul 28, 2006 10:40 AM
