Head Gasket Question
Old Mar 24, 2007 | 11:19 AM
Truckman's Avatar
Question Head Gasket Question
What are the chances of a re torque on the head to get the gasket to stop seeping a little? What is the correct torque? if anyone knows
Put a comp and boost elbow on three weeks ago and now the head gasket is wet on the pass side. Already removed boost elbow.
Thanks
Old Mar 24, 2007 | 09:27 PM
clutch1's Avatar
do you know for sure that its just seeping outside? you can retorque all you want but never had seen any good from it
Old Mar 25, 2007 | 06:57 AM
Truckman's Avatar
Cool Outside
Yes I can see just a slight residue coming down the block, What a shame the engine now has about 25000 miles on it.
I will find out what the correct torque is and check it this morning while it is cold.
Thanks,, Not what I wanted to hear.. ha ha
I guess I will sell the new comp. Didnt even get a chance to tap the pump..
Old Mar 26, 2007 | 09:30 AM
Truckman's Avatar
Question Sequence
Anybody Have the specs for that? Torque sequence and head bolt FT/Lbs?
Thanks
Old Mar 27, 2007 | 10:59 PM
Hemi Cat's Avatar
Torque spec's are, 66#ft on all bolts in sequence, recheck torque, then # 4, 5, 12, 13, 20, & 21 to 89#ft, recheck torque, then mark the bolt heads and turn additional 90 deg. All torques must be in sequence, the boolts that get 89# are the long bolts. Hope this helps.
ted_pulliam
Jul 16, 2009 11:33 AM
wildchild97
Sep 25, 2007 02:44 PM
blueberry
Feb 7, 2007 05:34 PM
Conn
Dec 29, 2006 06:30 AM
MADSEN
Oct 7, 2004 09:43 PM
