Control module gone bad?
Ok guys get this:
turn key on, all lights come on, sounds normal. As soon as the ABS light goes off, all dash lights come on. Headlight switch is OFF but ALL gauges are lit up. Headlights don't work...nor do the flashers....nor do the brake lights....only the 3rd brake light works. outside temp gauge reads "--"
truck starts fine and runs fine. infact it can spin all 4 wheels. but no headlights or brake lights.....or thermometer.
what exactly is that?
now i have 2 codes too...
p0602 ECM Fueling Calibration Error/ECM Internal fault
p2509 P2509-PCM/ECM power input signal intermitent
back in December the cruise control would quit working randomly...but other times work
then SERV 4wd would occassionally come on. Dealer pulled codes....say 2wd, 4hi, and 4low circuits open.
last friday it was eating starter relays....
wednesday lights would come on and off randomly
yesterday all dash lights come on with no other lights
today it only runs for 3 seconds then dies.
HELP.
gooseneck will be here in the morning to load my truck up. its gonna ride a gooseneck trailer to the dyno event
HELP.
how about unhooking the batteries for awhile? since most things are controlled by module nowadays, it may be something corrupt and a memory clear might help. just a thought.
Bullydog was stumped when i called them....but ofcourse they would be.
main ECM is fine, i can still retrieve codes from it....even load and unload bullydog. theres just communication errors between the ECM and something else.
dealer said what Bob said....tipm
