hard,or may not start
Old Mar 2, 2003 | 10:12 AM
modguy's Avatar
have 99 QC,4whl dr,after long road trip and stopping for fuel truck would not start,after 20,30 minutes<br>or so finally started but died when put into gear (atuomatic),finally restarted died again when put into gear<br>5,10 minutes later started ,used brake to keep RMP's up and took off,drove another hour or so stopped<br>for the night.Next am started right up,took off,ran fine first few stops then started dying again.Came <br>home,installed new filter,VERY HARD to start,same problem of dying,changed lift pump (103,000)on or-<br>iginal pump.same problem of dying.Installed pressure guage at filter, both sides,no pressure cranking<br>13/15 when running,still dies when put in gear.HELP,HELP!!!!!<br> THANKS<br> modguy
Old Mar 2, 2003 | 12:24 PM
Smokee's Avatar
Re:hard,or may not start
I don't know much about those trucks with all the extra valves, but I would bet on the problem being the rubber fuel hoses drawing air. You stop, the engine cools a bit, fuel contracts, air enters. Something like that.
Good luck.
george
Old Mar 2, 2003 | 12:45 PM
rich's Avatar
<br>i dont think your getting air in the lines i believe its an electrical problem. give me some time and i will try to look it up in one of my manuals
Old Mar 3, 2003 | 08:43 AM
modguy's Avatar
Does anyone have any ideas ,tried eveything I can think of on the hard to start,wont start 99 Cummins<br>open to any suggestions,dont want to go to dealer.<br><br> Thanks,<br> modguy
Old Mar 3, 2003 | 02:25 PM
DieselDaze's Avatar
I'll take a guess here...<br><br>Have you tried to reset your APPS?<br>I have no idea if this is going to work, just a guess.<br><br>https://www.dieseltruckresource.com/...p;onlynewfaq=1<br><br>May also be your idle speed is too low (in gear), but I will admit that I dont know if your idle speed would affect its ability to start ???<br><br>Good luck.<br>Rich
Old Mar 3, 2003 | 05:06 PM
modguy's Avatar
Just returned from &quot;***********&quot; after scratching their heads since about 9:45 this am,it is now <br>5:45 pm ,they decided it is an injector pump computer something or other breaking down when it get's<br>hot. I don't whether or not to buy this assesment or not ,they are saying it's an $1800.00 fix job.Can <br>anyone confirm this or not ????? The reason for the 1800.00 cost is my 100,000 went out about 2 weeks<br>ago,(103,000)now.<br> Thank's<br> modguy<br><br> Thanks to all for the responses so far!!!!
Tallguy67
May 11, 2014 12:35 AM
madhat
May 26, 2007 10:58 PM
John Faughn
Oct 1, 2006 12:54 AM
Bart Timothy
May 4, 2006 04:53 AM
