A gorilla put on my oil filter!
Old Mar 4, 2008 | 09:32 PM
PChouinard's Avatar
I hit the battery, not the alternator terminal. Will that blow the same fuse? What doesn't work if the fuse is blown (everything seems to work OK)
This is why you need to disconnect the negatives terminalS anytime you go under the hood with a tool. You never intend to hit a pos terminal while touching ground, but it does happen. It only takes a fraction of a second to arc a tool to a post, have the tool heat up, burn your hand, then watch the fireworks begin. It doesn't take long to reprogram your radio stations. We never seem to have the time or money to do it right the first time, but we always have the time and money to do it twice with more parts...
Old Mar 4, 2008 | 10:27 PM
Deezel Nate's Avatar
I don't even have any radio stations programmed on mine. Shoot the time still is the hour ahead time from last summer cause I can't remember how to change it (aftermarket stereo)
Old Mar 5, 2008 | 08:47 AM
bentwings's Avatar
DN... haha same here. I think daylight time starts shortly so I'll be good to go then without touching it. I think you have to push a pointy thing in the hole to set the time. Can't remember. I don't even know if the radio works. The cd player still works I think. I haven't used it in a long time though.
Gotta love the straight pipe. It probably costs at least 1 mpg. haha
Lenny Boysen
Sep 4, 2013 11:19 PM
barngal6
Jul 5, 2009 06:49 PM
Common
Apr 15, 2009 04:43 PM
adamsmarshall
Feb 21, 2008 03:36 PM
03dodgeoffroad1
Jul 3, 2007 05:54 PM
