fuel transfer pump problem????
Old Nov 8, 2005 | 05:43 PM
Spike's Avatar
98 dodge ram 2500 w/ 24 v engine i was running low on fuel when i thought i ran out after puting 10 gal's of fuel and filling the fuel filter. i opend the blead screw on top of the fuel filter housing and when i cycle the ignition to activate the fuel transfer pump i do not get any fuel out of the bleed screw but i can hear and feel the pump doing somthing but i am cot getting any fuel to the filter.
Old Nov 8, 2005 | 08:34 PM
Shovelhead's Avatar
Administrator / Scooter Bum
From the symtoms you describe........your pump is toast.
Several have posted about pumps that will run, but not move fuel.
Old Nov 9, 2005 | 11:33 AM
johns99's Avatar
try opening the top of the fuel filter housing and crank but do not start the pump should run for 25 seconds do this a few times and see if you can get any fuel out of it. if you do then loosen the line at the number one injector and crank away after you plug the top of the fuel filter. and you should eventually get fuel out of it. tighten the line back up and start cranking some more. DONT USE EATHER. it will cause the cylinders to dry up and can cause fires do to the grid heater. Dont worry about cranking on it for long times the starter will handle it, I have 1st hand experiance with this. If all else fails put a new pump in it and follow the same procudure.
Old Nov 9, 2005 | 11:52 PM
Timmay2's Avatar
Just happened to me. Changed the filter, pump sounds like its workin but no fuel. Replaced the pump and all is well again in expensive money pit dodge land.
Old Nov 10, 2005 | 05:46 AM
Shovelhead's Avatar
Disclaimer:
Not in any way affiliated with this company.
This is the cheapest Cummins lift pump I've seen on the web.
www.hoeslidiesel.com look for internet specials.
The dealers want $300+ for the exact same pump.
Others have used the Carter pump from NAPA as a replacement.
Ahousat Diesel
22
Jan 12, 2014 12:05 PM
derceg
Dec 23, 2009 07:24 PM
csramsey640
Jul 6, 2006 04:44 PM
8mpg
May 22, 2006 01:35 PM
