fuel pressure fitting
Old Apr 9, 2007 | 09:48 AM
mwolfe's Avatar
Does Anybody Know A Part Number For The Fitting At The Pump To Be Able To Check Fuel Pressure , 12 And 24 Valve Engines
Old Apr 9, 2007 | 10:16 AM
infidel's Avatar
Can't help you with the 24 valve number but am certain that no fitting is available for a 12 valve. You have to drill and tap the injection pump banjo bolt yourself. A very easy job.
Old Apr 9, 2007 | 10:51 AM
Dr. Evil's Avatar
And any place that sells guages can get you a tapped banjo bolt for the 24V's (or you could probably tap your own - 1/8" NPT)
www.vulcanperformance.com is an awful handy place to find most of the fittings you'll ever need.
Old Apr 9, 2007 | 06:10 PM
BCSCUMMINS's Avatar
On a 24v you can use the Shredder valve below the VP
Old Apr 9, 2007 | 06:16 PM
Dr. Evil's Avatar
That is true, but its not the best for a long term setup.
Old Apr 9, 2007 | 06:42 PM
CobraCTD's Avatar
Tapped Banjo Bolt
Try this...
http://www.genosgarage.com/prodinfo....BF-LONG-TAPPED
Sasqoutch
Aug 31, 2007 06:50 PM
SSweeney
Jul 11, 2006 07:03 PM
trik396
Mar 9, 2006 04:40 PM
shoe
Mar 28, 2005 03:14 PM
CTDHokie
Jul 22, 2004 05:24 PM
