Front Turn Signals
Old Apr 21, 2004 | 09:38 PM
signature600's Avatar
Unhappy Front Turn Signals
How in the heck do you get to the front turn signal bulbs in these trucks? I need to change one, and thought I should do both anyway, but I can't get to them. I assume that you take the batteries out and go from in there, but the two bolts on the inside of the fender are rusted up and I don't have time to mess with it tonight, so any comments are appreciated for tommorrow.
Thanks in advance,
Chris
Old Apr 21, 2004 | 10:45 PM
apache's Avatar
Im not positive on the front blinkers,but most of the marker lights including the front side blinker/markers just twist out of the housing. 1/4 turn and pull out. Hum, now you got me thinkin about mine
Old Apr 21, 2004 | 11:10 PM
infidel's Avatar
You really should get an owners manual, it will tell you how and costs less than $10. You don't even need to open the hood, on the lower outward side of the turn signal remove the one phillips screw, pull the whole unit forward. The rest is easy to figure out.
Old Apr 22, 2004 | 04:47 PM
Scubasteve's Avatar
Below the marker lamp you will see a philips screw on the side. Remove that screw then pull the light forward out of its slots put the new bulb in and your good to go..
Good Luck
Jason
Old Apr 22, 2004 | 07:30 PM
OK, Thanks, BUT
Those screws are rounded out!
Can I drill them out, or will I crack the plastic. I have plenty of replacements available.
Thanks,
Chris
Jim Lane
May 15, 2024 05:41 PM
Jklawinsky
Mar 21, 2012 09:51 AM
96_12V
Aug 12, 2011 01:15 AM
HitTheRoad
Jan 20, 2003 10:20 PM
boehunter49
Nov 28, 2002 06:41 PM
