Lost turn signals, brake lights now front & rear?
Old Jul 14, 2011 | 09:45 PM
96_12V's Avatar
Hello all - long time since I've been on here. Still have old '96, though someone's trying to buy it from me.
Tonight headed home, I noted the turn signals where not flashing in the dash panel. puzzled, I looked in rearview to see if the brake lights worked as it was dark out. They do...but the right turn signal light in the dash lit up as well with the brakes! And as I turned into my drive, I could see the front turn signal lights were going to their brighter setting when applying the brakes!
So - any ideas on what's up here? The bright lights do turn on and off normally, I can here the signal trying to work. Did I loose a switch? Thanks for your insight!
Old Jul 14, 2011 | 11:05 PM
Polaraco's Avatar
Old Mopar Aficionado Extraordinaire
Could be the Turn signal switch. All that stuff goes through it.
Old Jul 23, 2011 | 08:45 PM
Kennys's Avatar
Check the bulbs before you take everything apart. Had a weird problem on a car several years ago. Finally found it had a bad bulb causing the problem.
Old Jul 23, 2011 | 10:20 PM
cj360trider's Avatar
bulb is completely possible. from what you describe it sounds as if you have a loose or broken ground wire somewhere. also do not rule out the brake switch or the multifunction switch.
Old Aug 11, 2011 | 06:36 AM
Stamey's Avatar
Hazard switch. The way this system is designed the brake and turn signals are the same circuit. If you turn on your hazard lights and hit the brake you will get that exact behavior. The problem is likely in your multi-function switch, which controls the hazard, turn signals, dimmer and wipers.
Could be as simple as wiggling your hazard switch, but that isn't a long-term fix.
Chris
Old Aug 11, 2011 | 09:12 AM
infidel's Avatar
Trailer jack packed full of wet mud can cause similar problems.
Old Aug 11, 2011 | 02:40 PM
CarlJensen's Avatar
How the hell do you know that one Bill??
Old Aug 11, 2011 | 09:56 PM
the dude lives in montana........more mud than roads in montana. on top of that bill is the Mah Hah Cummins Guru so.....yeah lol
Old Aug 11, 2011 | 10:46 PM
torquefan's Avatar
Chris
This is my thought too. I'd work the hazard switch up and down a few times and see if it changes.
Old Aug 11, 2011 | 11:39 PM
Polaraco's Avatar
I said Turn signal switch a long time ago. It's all one unit
Old Aug 12, 2011 | 01:15 AM
zthatzmanz28's Avatar
The FSM has a continuity test for the multi-function aka signal/hazard switch..
Mattster
Sep 14, 2019 12:25 AM
Rbhart
Mar 1, 2013 08:34 AM
oilcan64
Jul 29, 2012 09:24 PM
Fastback66
Jun 28, 2009 08:48 AM
hohardcastle
Jan 24, 2006 01:17 AM
