Front end Rattle
Old Aug 26, 2004 | 10:53 PM
capt.Ron's Avatar
I think I can... I think...
Front end Rattle
I have a 96 2500 that has developed rattle on both sides of the front end.
I inspected it and found that the lower ball joints were pretty badly worn so I replaced them, the rattle is still there.
Just wondering if this is a common problem and if anyone knows what the problem might be. I've also check and replaced the bearings as well.
Old Aug 27, 2004 | 02:43 AM
P.O.R.'s Avatar
check your lower shock bolts and maybe your lower contol arm bolts/bushings.i have had the bolt break on the axle end of the lower contol arm also have had the bushing rattling around in the control arm..
Old Aug 27, 2004 | 10:55 AM
shortround's Avatar
From: In the middle of Weather Dry Creek Farm in Avilla, Arkansas
I thought the rattle from the front was just the 1st and 2nd gen trucks engine
Old Aug 27, 2004 | 12:13 PM
nitrousn's Avatar
ditto on the lower shock bolts.
Old Aug 29, 2004 | 11:42 AM
dodgediesel4x4's Avatar
If everything mentioned above seems to be in good working order, then it might also be your shocks. How old are they? My truck has been making some extra front end noise lately also. I also tried tightening everything up underneath, but no luck so far. I'm gonna give it another try today and see if I can find that rattle. Good luck.
Old Sep 2, 2004 | 08:33 PM
ironman's Avatar
Rattle in my front end was bad 4x4 axle Ujoints. Clunked all the time till I rolled up the windows and turned up the stereo.
12PACK
13
Apr 11, 2006 12:27 AM
Geico266
Jul 1, 2005 04:12 PM
Cummins600
May 19, 2005 10:44 PM
capt.Ron
16
Oct 25, 2004 10:17 PM
