Front Axle
Front Axle
How do I find out which front axle is on my truck? <br><br>I hope that a kind member of the DTR will come over here shortly and fetch me some brake rotors. Autozone lists 2 types of axles. 7500 and 8800 lbs. I don't know which one I've got and the rotors are different. ???<br><br>Thanks in advance<br><br>AlpineRAM
Re:Front Axle
For some reason, I have been thinking that all 2500's with a diesel are the<br>8800 GVW rating. You should have a sticker on the drivers door jamb with<br>that information. Maybe someone can correct me if I am wrong. <br>I have an 8800# rating, and my front axle is a Dana 60.<br><br>Hope that helps.
Guest
Posts: n/a
Re:Front Axle
The weight should be posted on the tag on the drives door, I think it is on the driver door.<br><br>By the prices on the rotors for the axles<br><br>the 7500 is only like $22.00<br>the 8800 is $44.00 a big difference. If I was guess I bet your got the 8800. but look at the tag on your door on the driver side.
Re:Front Axle
Alpine the axle in your truck is a HD60F-4500lbs, the other axle they are refering to is a HD44F used in a1/2 or light 3/4 ton. All the diesels have the bigger axle as you probably are about 4300lbs empty on the front. This axle is also standard equipment on Chev 1 tons until 1989 and some parts are interchangable with the Dodge. Ford also used this axle but I am not sure exactly which years as they are not consistant, up to 2000 not all diesel Fords had 60's some had a Dana 50F which is unique to them. You can also see a 60F casting mark on the front of the gear case casting. PK
Re:Front Axle
Changed my rotors last month. 8800lbs. Lots of fun. be very careful with axles,up&down, in & out, % side to side. Now,,, both sides leak oil. >
Have not gotten to that job yet. Special tools required. [undecided] Good Luck.
csramsey640
Jun 4, 2014 10:31 PM
rustydeeretech
17
May 21, 2011 03:05 PM
case310350
Jun 23, 2010 09:03 PM
