Fog/Driving light wiring
Old Nov 7, 2005 | 09:08 PM
Drivenriden's Avatar
I have a 04 2500, bought it with the fog/driving lights already on. The guy wired the fog/driving lights to stay on even when the high beams are on. I need them to shut down to pass inspection. He did a great job wiring them, they look like factory install, but he wired something direct & I can't find it. Anyone have any ideas?
Thanks, Al Venn
Old Nov 7, 2005 | 09:21 PM
Nascarcamper's Avatar
My fogs stay on with the parking lights, this was done by following this diagram from Bubba CTD here on the board, here is the link, all that was done was the wire that you can see in the fuse box under the hood, hope this helps.
Old Nov 7, 2005 | 10:04 PM
donhov's Avatar
I did my own wiring and removed the headlight assembly and with the factory fog light kit and supplied connectors I wired the signal wire from the parking lights so that the fog's come on as long as the parking lights are on, they also come on with low beams and high beams.
Look for a wire going to the (I think) left headlight area that isn't an original wire. It should be connected to the wire that controls only the low beam if you need as it should have come from the factory.
Hope this helps a little...Don
Old Nov 7, 2005 | 11:52 PM
Thanks, figured it out
Thanks NASCAR Camper & Don. It was wired like Don's lights. I had to take the left HD light out & connect a relay to the high beam light wire, so when I threw the HBs on it will cut out the fog/driving lights. Did I mention how much I dislike Virginia DMV inspections? Moving to Norfolk this week, fun, fun. Thanks again for your help.
Al
Old Nov 8, 2005 | 02:01 PM
fredbert's Avatar
How about simply disconnecting the foglights for the duration of the inspection? Foglights are a factory option and many trucks came without them. I love beating the system!
Doj Dewd
Sep 21, 2011 03:14 PM
Flying Ram
Jan 31, 2009 09:10 AM
AndyZ
May 13, 2005 12:01 PM
KansasMan
Aug 25, 2004 08:30 AM
RATTLINRAM
Jan 19, 2003 08:23 PM
