Flagging Temp Gauge
Old Jun 14, 2008 | 07:36 PM
BigIron70's Avatar
Cummins Guru
Flagging Temp Gauge
I have 99 Ram 2500 12v. I replaced radiator and t-stat, still have temp gauge going from 190 to 160 slowly. I removed vent hose and added coolant until I had steady stream out vent. Still having same problem, I ordered another t-stat hoping maybe just bad t-stat. Anyone seen this before?
Old Jun 14, 2008 | 10:10 PM
Common's Avatar
Sounds 100% normal to me.
Old Jun 15, 2008 | 09:29 AM
infidel's Avatar
Cummins says,
THE COOLING SYSTEM USED ON THE CUMMINS DIESEL ENGINE EQUIPPED VEHICLES PROVIDES THE CAPACITY AND PROTECTION OF THE HIGHER GVWR AND GCWR RATINGS AVAILABLE ON THESE VEHICLES. OWNERS SHOULD BE ADVISED OF THE NORMAL SLOWER WARM UP AND LOWER ENGINE OPERATING TEMPERATURES ASSOCIATED WITH DIESEL ENGINES.
THE COOLANT TEMPERATURE GAUGE WILL FLUCTUATE ON DIESEL ENGINE EQUIPPED VEHICLES. IT IS INFLUENCED BY VEHICLE LOAD, OUTSIDE AMBIENT TEMPERATURE AND EXTENDED IDLE TIME. THIS FUNCTION IS CONSIDERED NORMAL
mar67655
Mar 21, 2009 05:35 AM
DennisT
May 11, 2007 08:58 PM
turbox2
Feb 6, 2006 07:44 PM
Bad Ramer Jamer
Dec 1, 2005 02:30 PM
firesine
Nov 24, 2005 10:58 AM
