fass install need help
Old Nov 11, 2006 | 02:29 PM
Firedog12's Avatar
I have my new FASS 95/95 1008 I,m confused I'm not sure how to say it but here goes. On the front it is stamped H for heater (option) there is a flare fitting in the middle (not marked) and to the right there is a R stamped and plugged so I take the plug out install the fitting and double check instruction and it said to hook return to the flare fitting which is in the middle. I thought the middle connection would go to the engine(there is no E stamped on the pump) then the 90 fitting on the top I thought was for the fuel pressure gage. so who can help me that has put a FASS system on? I really do not want to wait till monday to find out.
Old Nov 11, 2006 | 04:16 PM
Firedog12's Avatar
Wow!! guess I stumped the best nobody wants to jump in Hmmm
Old Nov 11, 2006 | 08:32 PM
rodsram's Avatar
If you do a search, spend a bit of time it is amazing what you will find.
I have not read this, so I hope my sarcasm is not in vaine.
If you do not find the answers, post again and I will continue the search.
Best of luck
http://www.acptee.com/dieselpp/pdfs/...leShooting.pdf
EDIT: I can't get the link to work, it is at the bottom of diesel dan's signature, hopefully he will get to this before Monday
Old Nov 11, 2006 | 08:44 PM
rodsram's Avatar
http://cumminsforum.com/forum/showthread.pp?t=5440
Try this, it is from another site, may or may not be of use:
Old Nov 11, 2006 | 09:14 PM
Firedog12's Avatar
nice site but it was not the same as I have. I have the filter and water seperator on mine just not sure why they did not stamp E on the port
Old Nov 11, 2006 | 09:59 PM
Firedog12's Avatar
thanks for your help I went through some sights and reread the manual I guess the middle port is the return port
Old Nov 11, 2006 | 11:17 PM
FMB's Avatar
FMB
Originally Posted by Firedog12
I have my new FASS 95/95 1008 ... and to the right there is a R stamped and plugged ... I really do not want to wait till monday to find out.
... I guess the middle port is the return port
It seems to me, the port marked with the "R" is the return port. See page 8 at http://www.dieselpp.com/pdfs/install...5-200-1008.pdf or http://tinyurl.com/y8jefn and find your make/model of FASS. Good Luck.
Old Nov 13, 2006 | 06:17 PM
Diesel-Dan's Avatar
OK....here is the pump you have. The top BRASS fitting is the supply to the injection pump. The middle fitting, as you refered to it, is indeed the return to the tank (Fitting directly above and to the left of the fuel filter). The suction line is on the back side (right side of the pump).
klx650a2
Jan 31, 2008 09:44 AM
kennyblatz
Sep 14, 2007 02:23 PM
rjm022
Sep 17, 2006 11:28 AM
Flatty
Apr 25, 2005 12:49 PM
ralphie
Apr 21, 2005 12:51 PM
