EZ Change torque setting?
Old Sep 4, 2005 | 09:02 PM
TBM Ram's Avatar
I started to change my oil earlier this afternoon, and was also planning on installing the new EZ Change plug that i recently bought from Geno's. Well i went to install the plug and on the little plastic case it is in the torque setting is rubbed off and i can not clearly read the correct number.
Does anyone know the correct torque setting to torque the drain plug to?
Thanks,
Tim
Old Sep 4, 2005 | 10:25 PM
dodgediesel4x4's Avatar
Not sure of the setting, but make sure you tighten the helk outta that thing. I'd say go higher than what they reccommend. I've heard of more than a couple of guys having that thing break loose and come undone, thus leaking oil all over the place. Not a good thing in my book.
Old Sep 6, 2005 | 09:58 PM
TBM Ram's Avatar
It ended up being 40 ft lbs. They were closed for the holiday weekend, and i called them earlier today. I went ahead and put the regular drain plug in for now, and i'll change to the EZ Change plug next oil change.
Tim
thor1721
Dec 29, 2010 10:58 PM
artieb
Aug 23, 2010 11:32 AM
p.o.s.
May 16, 2009 09:12 PM
ruquik
Feb 11, 2006 10:41 AM
Maccandy
Jun 5, 2004 03:06 PM
