Excessive EGTS 5 valves replaced...What do i do
Old May 18, 2007 | 11:08 PM
powerstrokin03's Avatar
Long story short, 2 bent push rods, pulled head and installed 5 valves. I am currious as to why only 5 and not 6. I though they would be damaged in pairs. Installed head and tested. Temps are around 1400 in under half throttle, no boxes on. Where do i start? I am concerned about the 5 valves and why they didnt replace the one with the 5th valve to make 6 valves. I need help please. Also, rail pressure fluctuates around 200-500 psi when i am driving. It sometimes is all over the place. What are your guys thoughts?
Old May 19, 2007 | 04:43 AM
AlpineRAM's Avatar
You have 12 exhaust valves- so I think they will have inspected them and replaced as necessary. With 2 bent pushrods you have 4 damaged valves.
To me your EGTs sound like either no boost or a slipped cam.
Why were your pushrods bent and the valves shot? Did you determine the cause?
Old May 19, 2007 | 04:52 AM
greasemonki's Avatar
I agree with the previous post. Bent pushrods to me, points more to slipped cam. You need to find out what caused the pushrods to bend, and what happened to the valves. Good luck
Old May 19, 2007 | 09:11 AM
they werent correctly seated in the tappets, which caused them to bend. But wouldnt if i bent one exhuast valve the other would be bent. Both in cylider 4 were bent and one in 5. why not both in 5?
Old May 22, 2007 | 01:41 PM
cincydiesel's Avatar
Was this all carried under warranty work?
Old May 22, 2007 | 01:52 PM
oh no, straight out of my pocket.....you pay to play
erf2006
19
Mar 24, 2008 06:36 AM
NJMurvin
48
Oct 14, 2004 09:16 AM
winner172
May 18, 2003 02:19 PM
wick
Jan 25, 2003 09:21 PM
BigBlue
Jan 22, 2003 07:49 PM
