Error Codes.....
Just found out one of them is a lift pump problem. Should I go with the OEM from Genos? What is the other options and prices? Can any Dodge dealership install all options for repair (FAAS Glaisier)? The FAAS can't work if the original LP is dead right?
I would go with an aftermarket pump, they are not that bad.
How many miles do you have on the truck? The fuel pump is the canister mounted one, correct?
I personally would go with a Air Dog or raptor 100 (if no power adders) and a AD 150 if you have power adders. The installs are easy if you have some mechanical ability, and they have good customer service. Look on the pureflow technologies website, or the DTR store here.
What is an air dog or the raptor? What do they cost? I just ordered the OEM one from Geno's for $179. I do not have any mechanical ability.
air dog and raptor are 100gph aftermarket lift pumps. dealers usually won't install aftermarket stuff like that but for your truck a stock lift pump should be all you need and you'll save a few hundred $$$$
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
