Engine stalls
Engine stalls
Any one have a problem with their 2001 dodge diesel stalling when put in gear , runs fine down the road. had scanned no codes. seems like it starts acting up when the transmission get about 150 degrees. The engine rpms at a stop do move up and down 50 rpms can not put into reverse or drive with out it stalling.
engine stalls
Found my problem torque converter is coming a part, fluid draining out of cooling lines is all metalic, cheap converter only 55000.miles on that converter, will replace with a lot better one. around 3k later i should be set.
kinghomes
Sep 17, 2007 10:24 PM
Hounddog
Feb 14, 2006 06:33 PM
