Engine idle's at 1700 RPM
Old Oct 20, 2008 | 12:35 AM
BigIron70's Avatar
Cummins Guru
I have a 2001 Ram 24 valve all stock. I have a code P0121-ACCEL POS SENSOR VOLTS DO NOT AGREE W/IDLE VALID SIGNAL. Engine idles at 1700 RPM, I replaced APP sensor it reads 18% at idle but did not fix problem. I checked all wiring to ECM and APP and is in spec. I'm thinking ECM is bad, anyone had this problem?
Old Oct 21, 2008 | 02:57 PM
BigIron70's Avatar
Cummins Guru
Finally fixed problem, after getting a bad ECM from Chrysler that wouldn't program. Second reman worked and was able to program it. Turbo boost sensor was also bad. ECM problems that aren't completely DOA can drive me
BigDiesels
Dec 28, 2007 08:23 PM
socal 610
May 23, 2006 06:34 AM
gr898
Feb 27, 2005 07:14 PM
fishin fever
Feb 22, 2004 08:32 PM
phox_mulder
Apr 30, 2003 03:24 PM
