electrical problem
Old Feb 17, 2003 | 07:53 PM
klyne's Avatar
electrical problem
have a 2002 3500 4x4 h.o.cummins and the intermediate wiper and key in ignition buzzer quit working at the same time.are they tied in together and what is it i need to fix it happened while installing trailer brakes could i have bump something
Old Feb 17, 2003 | 09:56 PM
Stamey's Avatar
Re:electrical problem
You should check fuses, inside the truck and outside, over the left fenderwell.<br><br><br>Chris
Old Feb 20, 2003 | 05:59 PM
klyne's Avatar
checked all fuses and all off them are good any suggestions?
Old Feb 20, 2003 | 07:25 PM
rich's Avatar
Check that black box under the dash above the brake pedal sounds like you might have knocked a plug loose. that box controls lot of things
Old Feb 20, 2003 | 09:04 PM
Commatoze's Avatar
My guess is your Central Timer Module, or CTM is hosed. Strange as it may seem, the intermittent wipers, and the &quot;ding!,ding! ding!....&quot; used for alert alarms are generated by the CTM. It's located under the driver side end of the instrument panel, inboard of the instrument panel steering column opening. Does it work for seatbelts and lights on? If not, I'd really zero in on the CTM.
Tom Hybiske
bigredbrick
May 1, 2003 11:59 PM
feets
Mar 17, 2003 09:57 AM
al
Nov 18, 2002 11:03 AM
MD Muhr
Nov 14, 2002 05:27 PM
turbospl311
Oct 14, 2002 08:23 AM
