Electrial Problem Help!!!
Old Jan 2, 2008 | 08:52 PM
francis's Avatar
Have A 00 Ctd And Where The Odomtere Is It Says "no Bus" And Thats It. The Gagues Dont Work And The Check Engine Light Is On And The Low Fuel Light Is On And Abs.
What Could Be The Problem
Thanks James
Old Jan 3, 2008 | 01:03 AM
Luckyrogue's Avatar
Hey there, I'm not of any help tonight but I have a friend at a diesel shop and I will see if he can pull anything up on the computer tomorrow! I will let you know if I find anything either way!
Luke
Old Jan 3, 2008 | 02:22 PM
R.T.D.H.S.P.'s Avatar
Take your dah bezel off so that you can gain access to the guage cluster. The whole cluster plugs in to a male/female connector on the reverse side. Chances are, its just not making a good connection. Just give a gentle push to make sure its good and connected. Disconnect your batteries, then reconnect, and you should be worry free.
Old Jan 3, 2008 | 05:16 PM
johnh's Avatar
Thanks James
you didn't say if it runs or not!!!
Old Jan 3, 2008 | 06:38 PM
francis's Avatar
no the truck does not run it turns over but will not run
thanks
Old Jan 3, 2008 | 10:47 PM
Dieselboys's Avatar
no Bus refers to the can Bus, they are two data wires that run to your computer, and are pretty much the lifeline of an electronic diesel engine, they will be twisted together one over the top of the other like a strand of cable but also must be completely insulated from one another, my suggestion is to take it somewhere, and have it properly diagnosed, this would explain cranking and not fireing and also the gauges not working
Jan 28, 2012 10:19 PM
callum
Nov 21, 2004 07:04 PM
dogman
Dec 27, 2003 07:06 PM
