ecm swap
ecm swap
my truck has the common dead pedal syndrome.i have replaced the sensors and the lift pump.ip has 38k.removed the ip and had it tested at a pump shop,its ok.new apps does not register at the ecu at times.shutting of the key restores the truck to normal for 20 to 25 minutes
6spd05Dually
Mar 12, 2011 12:19 PM
jrussell
17
Sep 17, 2007 06:38 PM
Ohio Joe
Jul 12, 2004 12:13 PM
You`ll let the smoke out.
It`s really hard to put it back, and very expensive too...
