Dying on corners
Dying on corners
I have a 02 that dies when turning a corner w/half tank of fuel. Put a electric frame mounted pump an that didn't fix it. Anybody know how fuel lines run in tank? Thinking it may be sucking air somewhere. Thanks
You need to drop the tank or tilt up the bed (easier) and remove the tank module.
Once you have it apart you'll see how the module was put together with sharp self tapping screws that are very good at puncturing the pickup hose.
If one is punctured you might want to consider replacing the the pickups with a Vulcan Drawstraw.
wexman
Apr 21, 2005 06:50 PM
