DTC code PO513 06 is dead
I installed the Bully Dog-TripleDog a few monthes ago, have had no problems. Then My friend bought a 06 Ford and We pulled the program off my 06 Dodge and put it back to stock, Uploaded it on the Ford for a while,then put the ford back to stock and uploaded to the Dodge. My Dodge started for about 10 seconds then died. I cannot get it to start now, I have put it back to Stock,still no start. Read the DTC it says PO336 Cranckshaft.PO513??? The BullyDog website doesnot have the PO513 on the DTC page.
I am wondering what that Dtc code is?
I thinking about taking truck to dealer, but will they detect Bullydog?
It happened Friday at 6 pm and everybody from bullydog is gone.
Thanks ahead of time for any Help
Casey T ***
Casey T ***
Had some free time, so thought I would do a search and see what I could come up with for you. Here is what the code is:
P0513....Incorrect Immobilizer Key
and here is a link to where someone had this code with Bully Dog
https://www.dieseltruckresource.com/...ighlight=p0513
Hope this helps
Hope this helps
This is what P0513 Incorrect Immobilizer Key.
What version of Bully dog do you ahve on your triple dog?
It sounds like your key has a chip and the ecu does not recognize it.
This happened to me when i first installed my bully dog. I had to take the truck back to the dealer and have it reflashed. If you run the latest version of bully dog you should not have a problem.
After the truck would not start I went in and downloaded the newest upgrade (2.3.4) (IT HAD 2.3.3) and installed back on the truck. Still will not start, just wondering if this is something that bullyDog can help with in the morning or do I have to take it to the dealer??
i had triple dog for my 03 dodge. i returned to stock, but failed to "uninstall program". put it on friends truck it worked fine. then back on mine. same problem. i was stuck with his vin number on the bullydog. mine was lost. called bullydog and they told me how to install a new program on my downloader. truck is fine now. call them
Well called Bullydog at 9:00am and they walked me through. Had part of his Vin number hung in the programer. They had me put some numbers in and redownload it and it started. Thanks for all of yalls help!!!!!!!!
600 Megawatts
Mar 26, 2008 07:09 PM
SwingingCCattle
Dec 26, 2006 12:46 PM
