Dealer needs heLP!!!!!
Old Jan 16, 2007 | 08:46 PM
wreckn1's Avatar
heres the deal for the past three months i have been dealing with my CEL light coming on and off, dealer is at wits end but we do have some good info, i think anyways, heres the deal my fuel pressue sensor voltage is telling the computer it wants anways between 70-90 volts, well normal voltage is 1.5-3.5 tops, we took a fuel pressure sensor off a BRAND new truck and the light still came on, meaning that the sensor is not bad, we also put on a new fuel control accuator to see if that had any issues with this, well that didnt change a thing.
My question is what would the cause be? any ideas at all?? here is what we are afraid of i did the bully dog try before you buy thing back in july, it wasnt in there more than maybe 6 hours, then after i did that i had them do the reflash for better fuel economy thing. If dealer calls star and reads these numbers etc, is star going to say, warrenty void because customer had a downloader in it?? or would the tri-b4 u buy thing totally have erased its self?? any help please???
Old Jan 16, 2007 | 09:41 PM
53 willys's Avatar
fill out your sig..
I posted in the other thread you started what year is this truck?? new??
Old Jan 16, 2007 | 09:44 PM
53 willys's Avatar
here is waht the code means, is this the ONLY code they have found?
P0148-HIGH PRESSURE COMMON RAIL (HPCR) CHECKSUM
WHEN MONITORED
While the engine is running.
SET CONDITION
A deviation between the fuel pressure set point and the actual fuel pressure.
POSSIBLE CAUSES
  • Others DTC's present
  • Fuel leaks
  • Fuel control actuator
  • Fuel pressure sensor
  • Cascade overflow valve
  • Check valve damaged or blocked
  • Fuel return lines obstruction, damage, or debris
  • Lift pump flow
  • Air in fuel system
  • Leaking fuel injectors or high pressure connectors
  • Pressure limiting valve
  • High pressure fuel pump
  • Intermittent condition
I know a few have had the check valve go bad??
Old Jan 17, 2007 | 03:57 AM
wreckn1's Avatar
yes this is the only code, and truck is an 05 with 40000
Old Jan 17, 2007 | 09:24 AM
XLR8R's Avatar
Could you fill out your sig, please?
captn.KIDD
15
Sep 14, 2008 07:25 PM
fflarry
Aug 25, 2007 10:39 AM
dddrott
Sep 30, 2003 09:17 AM
