Cranks but won't start
Old Jun 14, 2007 | 11:14 AM
Gunrunner's Avatar
2004 2500 srw. 24,000 mi.----Shut truck off a couple nights ago then went out in the morning and it cranks fine, but won't fire. Pulled top of filter canister and bumped starter and got plenty of fuel flow from lift pump. (did not do a fuel volume test yet) Cracked one of the lines coming off the fuel rail and got lots of fuel there also. There is also NO codes. You guys got any ideas? Thanks, Matt
Old Jun 14, 2007 | 01:38 PM
vzdude's Avatar
DTR's 'Go to Guy'
Could be any number of things. Are the injectors firing? any codes? How did you check for the no codes? Are you sure it is diesel coming out, not gas/kerosene? Lots of factors.
Old Jun 14, 2007 | 01:57 PM
Gunrunner's Avatar
Don't know if the injectors are firing---As stated before, there are no codes present when using the key on-off procedure---And it IS diesel coming out not gas or kerosene---Could be codes that have to be read with a STAR scan tool?
Old Jun 14, 2007 | 04:47 PM
H2SRDMB's Avatar
where abouts in vegas are you ! im in north vegas by lone mountain. willing to offer as mnuch of a hand as i can. not to good with 3rd gens. but 2 heads can be better than one
JMAHAN
Jan 19, 2009 09:18 PM
Glasshog
Jul 9, 2007 02:30 PM
Deese
Jul 4, 2007 06:42 PM
mikeyy
Feb 14, 2007 11:27 PM
oaborbag
Oct 31, 2006 05:49 AM
