Crank no start.
Old Jun 7, 2020 | 08:28 PM
boostinbrandon's Avatar
Crank no start.
Bought a 03 2WD Cummins 5.9 CR for my little brother from the company I work for however it’s currently in a no start state.
I’ve removed fuel lines from the lift pump - good pres/flow,
I’ve checked the relief valve and tried blocking said valve,
I’ve then moved onto checking the injection pump @ rail pressure and while cranking I see 0psi on a mechanical gauge installed to the relief location. (This test was tried before and after unplugging the FCA. No change in pressure reading).
so my question is it seems odd that I see 0psi, I’d understand 400psi ok weak pump but 0psi seems odd to me. Is there a key way that could have sheared off of the injection pump shaft? Or is 0psi a common thing and I should just replace the CP3.
thanks in advance,
brandon.
I’ve yet to dig into the injector return lines, even with leaky injectors I believe I should still see SOMETHING in pressure.
Old Jun 7, 2020 | 10:39 PM
nothingbutdarts's Avatar
Any codes??
Old Jul 11, 2020 | 07:00 PM
Jim McCrystal's Avatar
I am having the same problem. My 2000 2500 will start, get me where I am going but won't start again for an hour. I am not a dodge guy. I bought this used with 70,000 miles on it. If the mechanic can't figure it out, I'M SELLING THE POS AND GOING BACK TO FORD!!!!!
wolfmanwolfman3
Nov 16, 2008 03:59 PM
Robbsdpower
Apr 21, 2008 07:05 AM
BearKiller
Dec 29, 2007 01:16 PM
Sam Turner2
Aug 12, 2007 02:05 PM
West Coast
Nov 3, 2006 11:49 PM
