Cracked Block
Old Dec 11, 2005 | 12:23 PM
strokethis3500's Avatar
Cracked Block
I didnt put enough antifreeze in it and it cracked between 2 freeze plugs.. How would i go about welding that up?
Old Dec 11, 2005 | 12:37 PM
Tiny's Avatar
Do a search on Lock and Stitch method. Sometimes it works, and sometimes it does not.
Old Dec 11, 2005 | 02:40 PM
timcasbolt's Avatar
Might be a lot of work to get to it, but you'd want to drill a small hole at each end of the crack to stop it from running. Next, you should try to grind a V in the crack to get some penetration. Then weld it up with nickel. I like tig process, but experienced welders can do it with ni-rod and a buzz box. Try to get the weld area as clean and warm as possible for best results.
klx650a2
Apr 20, 2009 05:25 PM
Stamey
46
Feb 20, 2004 02:57 PM
patriot pearl blue
Nov 18, 2003 11:03 PM
Haulin_in_Dixie
Oct 27, 2003 09:59 AM
WVPANHANDLER
Feb 1, 2003 08:23 PM
