Compression Blow By
Old Nov 2, 2004 | 01:19 PM
seedy1's Avatar
Question Compression Blow By
My truck is beginning to leave a quater size spot of oil every night that is obviously coming from the crankcase vent. This has to be compression blow-by, right? Any recommendations on oil treatments or change of weight? Currently running Rotella 15 30. North Alabama.
1999 3500 4x4 Cummins 24 Valve
Old Nov 2, 2004 | 02:07 PM
Commatoze's Avatar
Probably, and it's normal. If your truck still has the collection bottle, you might want to unsrew it and dump the contents. I say "still" because many of us have removed the bottle, and run an extension hose right down below the front of the engine to prevent the oily mess.
Old Nov 5, 2004 | 09:46 PM
neveragain's Avatar
Wink engine problerms
I have been having this problem lately too so pleeeeese let me know if you come up with any thing . gutless wonder. drives just like a gas engine.No power!!!!!!! lots of revs just like a jimmy.
Old Nov 8, 2004 | 09:08 AM
seedy1's Avatar
I have changed oil from Rotella 15W40 to straight DELO 4o. Also, added 20% Lucas Oil Treatment. That seems to have illiminated the compression blow-by. At least, I do not see any new oil spots in the driveway! Anybody have any thoughts possitive or negative regarding my choice of oil?
Old Nov 8, 2004 | 04:15 PM
zack_76401's Avatar
From: Lingleville TX but active duty Air Force all over the world currently
i run rotella 15-40 too and the lucas......amkes mine worse but its a lot colder up here in the rockies than in alabama....I notice that when im at home in Texas i dont have this prob.....Im thinkin of going to a lighter oil during winter...
Old Nov 8, 2004 | 04:45 PM
Lil Dog's Avatar
Oil choice seems great.. The Rotella products have always been given the thumbs up..
As far as LUCAS goes.. Here is some reading for ya..
http://www.bobistheoilguy.com/images/lucas/lucas.htm
neveragain
I wonder if you must own a V-8 diesel.. This is the wrong forum for you.. BTW, there are some rather powerful CTD's in your town that I know personally.. You might get a surprise one day..
J-eh
Old Nov 8, 2004 | 05:33 PM
seedy1's Avatar
Lil Dog,
Checked out the Bobistheoilguy website...scary stuff. I feel like I need to go home and change my oil immediately! Clearly, the Lucas additive does not appear to be good for the engine. I have always been leary of putting additives of any type in any my trucks and this is the first time I have ever used an additive. I must say that adding the Lucas treatment and changing to a straight 40 weight has fixed my leak problem but, I would rather the truck drip a little oil than for it to have a catastophic oil system failure!
Now I am back to square one!! What do I do??!?! Should I go back to a 15W40 and let it drip or, do I stick with the straight 40 weight Delo that I have put in there? HELP!!!!
Old Nov 8, 2004 | 07:33 PM
infidel's Avatar
Put a pan in your driveway to catch the drip and don't worry about it.
A little drip is normal
The reason most diesels do this and gassers don't is because the gassers vent back into the air intake. Can't do that on turbo charged engine because of the higher pressure instead of vacuum.
Old Nov 8, 2004 | 10:34 PM
Lil Dog's Avatar
Well I never knew about the problems with additives either till I read that.. The demo in the stores looked good enough to me, but I always wondered.
The leak is normal venting and some oils are better at the vapour release than others.. The flow from the engine is the same, but some oils don't mist as other do. I have always seen the drip on all my trucks, I never worried about it till it starts coming from somewhere else.
There are separators out there that I remember on the TDR for vapour recovery. I think it was by a company called Airsep.. I am not sure..
Old Nov 9, 2004 | 08:29 AM
seedy1's Avatar
I will change my oil back to Rotella 15W40 and just put a pan out there to catch the oil. Talk about alot of greif for nothing...
I love this forum!!!!!
Thanks Guys!
kingofdodge7131
Nov 24, 2003 12:16 PM
geof
Nov 16, 2003 07:20 AM
SjLingenfelter
Jun 30, 2003 01:35 PM
