codes ?
P2509 Ecm/pcm Power Input Signal Intermittent
I would check batteries, pos. battery connections and pos. leads going to PCM, also check negative battery connections and as many ground contacts as you can find.
NCA
NCA
From: In Oroville, Ca., same house for past 46 yrs!
intermittent would indicate it could also be the ECm/PCM connectors located at the firewall pass side usually. Disconnect batts and then disconnect plug in connectors and clean good with contact cleaner, plug in and out several times and then spray again, then blow dry good and re-connect everything. If issue is not resolved, check further on power connections as per above advice.
I had the same issue and know what the problem was so good luck. Sometimes it interferes with the trans going into O.D. as well.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
StormTrooper
Mar 28, 2005 09:17 AM
