Center Carrier Bearing#####.
I have changed these bearings on both ford, & chevy., is ther some hidden sin ,i don"t remember
. bearing is frosen on spline shaft, i thought about chewing it off, (plastic theeth). Is this acommon thing on our dodges?SSSSOOO TELL me how to fix simplest way.
You might have to split the race. Cut the outer race off and then use a cutoff wheel to put a deep notch in the inner race. Then take a cold chisel and split the race, it will slide right off.
wana , thanks ,cut it off, .The bearing they gave me was too small dia. had to order one 1.5748 dia. be here tues. checking all u joints --don't want to do this again for , forever. will i have to have the bearing pressed on??
ajb1974
Mar 18, 2015 05:49 PM
JohnnyH
Apr 12, 2007 11:52 AM
Joseph H. Smith
16
Jan 6, 2007 08:13 PM
jaconst
Apr 2, 2006 03:02 PM
