Code P0483 Clutch fan or sensor?
Old Mar 28, 2010 | 08:10 AM
Rickysixx's Avatar
Had temp issue on last tow, engine light never came on but this code showed up. How do I know if it's fan or some sensor? Checked all wiring and conections.
2003 Ram 2500 4x4 longbed quad-cab, 4" Superlift, Edge E-Z, MBRP Turbo-Back, Dual 6" stacks.
Old Mar 29, 2010 | 10:58 AM
powderman426's Avatar
When using the key off on method, I get that code also. The fan seems to be spinning up ok, and temp seems solid, so I believe in my case at least it is a sensor problem. I am not doing anything till a real problem results from this. So basically i am saying it could just be a bad sensor. YMMV
Old Mar 29, 2010 | 12:18 PM
triton20x's Avatar
I had the same code a few months ago. I bought a scanner and cleared it out and it came back. Put a new fan clutch on and all is well. I bought my fan clutch at O Rielly's it is a Hayden sevier duty clutch and it only cost $218.00 alot cheaper than the dealer. You should check the wiring to make sure it didnt come unpluged first and if it didnt next step new fan clutch.
HIGHGEAR
Apr 1, 2008 09:36 PM
kelley15
Dec 13, 2007 06:28 PM
cquestad
0
Feb 28, 2006 12:49 PM
cc350
Nov 21, 2005 01:29 PM
