clueless!!!
Old Mar 17, 2010 | 06:19 PM
prittyboy's Avatar
clueless!!!
ok here it goes, 03 cummins 6spd had issues last week, cranked the truck let it warm up ran fine except it had a little miss to it while it was idling, killed it and got greedy for more power and changed the prong on my edge Ez to level 5 which after further investigation i dont think this is an old Ez that even has that level, restarted the truck and had no power, it would run but felt less than stock, pulled over killed it and changed the prong back to level 3, tried to crank it after that and would not start, it would spin over but not start, had my brother pull me and it would start, killed it and tried to restart and nothing, but it threw P0193 code, carried it to the shop and they did some testing and it showed to be the ECM, so i pulled it home and this time it would bearly run after a pull start, it did not have enough power to keep itself running, so today i get the new ECM put it on the truck and now it throws P2127, P0193, and still will not crank, tried to delete the codes by pulling the battery terminals off, nothing! tried using my superchip programmer to delete the codes, nothing! for some reason it will not delete the codes, im ****** and stumped! if anybody has ANY ideas or can give me some basic things to check it would be greatly appreciated thanks Michael
Old Mar 17, 2010 | 06:43 PM
megacabdad's Avatar
Take your Edge EZ off the truck completely.
And make sure your lift pump is functioning properly.
Old Mar 17, 2010 | 08:25 PM
prittyboy's Avatar
lift pump checked, good, i took both programmers off the truck after it would not crank the first time, and have not had them on since but thanks for the reply it is greatly appreciated, it became a lonely world when i ran out of ideas! lol
Old Mar 17, 2010 | 08:32 PM
madhat's Avatar
Administrator/Jarhead
One of those new codes is a TPS issue, the other one is another sensor. I'll have to look them up when I get home.
It could just be a bad connection from hooking and unhooking the Edge... I messed up a connection one time, my truck ran like 3 of the pistons were taking the day off.
Old Mar 17, 2010 | 08:51 PM
prittyboy's Avatar
thanks for the reply, u know i was kinda leanin in that direction about the connections but visually they look fine, the other code came up to be (0193 fuel rail senser circuit high) whats got me stumped is the fact i cant clear the codes
Old Mar 18, 2010 | 09:18 PM
prittyboy's Avatar
Unhappy
ok checked all conections and changed the fuel pressure sensor and still nothing!, i cant clear the code of P0193 i really dont want to send it to the dealer but im running out of ideas:
Old Mar 22, 2010 | 10:22 PM
prittyboy's Avatar
bump anyone
Old Mar 23, 2010 | 08:02 AM
loya 3500's Avatar
well have u fund a fix yet...
natlchamp2k4
Mar 28, 2007 04:17 PM
Machinos
Mar 6, 2007 09:30 PM
five20too
32
Oct 20, 2006 09:33 PM
viper20
Jun 21, 2006 01:44 PM
cortez
Apr 30, 2003 10:47 PM
