Check engine light
Old Jul 14, 2003 | 12:24 PM
99 cummins's Avatar
Check engine light
My check engine light just came on today. Is there an easy way to check the codes on these things and is this something that I need to let the truck sit until it is checked or can it be ignored for a day or two. it is a 99 3/4ton 4wd with a k & n breather kit and Comp box on it.
Old Jul 14, 2003 | 01:31 PM
firestorm's Avatar
Re:Check engine light
If you hold the trip/odometer button in while turning the key to the 'on' position, the computer will go into a self check mode.The gauges will all max out, one by one in this mode. When it is done in this mode, turn the key off. Then, turn the key on-off 3 times, ending in the on positon to retreive the codes. Below is a link that takes you right to the OBDII list of codes. <br><br>http://www.obdii.com/codes.html
Old Jul 15, 2003 | 06:06 AM
Alan_Reagan's Avatar
I don't think the 99 will display the codes. If not, go to Autozone and they will read them for you free of charge.
buddy26
Feb 15, 2008 12:17 PM
choppers555
Oct 16, 2007 12:29 PM
alltimelow1
Apr 6, 2005 07:28 PM
Fillerupsonny
Oct 9, 2002 06:01 PM
