Check Engine Code P0191
Old Jun 1, 2007 | 06:09 AM
MegaDawg's Avatar
Can't find code P0191. Anyone know what it means?
Old Jun 1, 2007 | 06:26 AM
annabelle's Avatar
http://www.canobd2.com/support/DTC_lookup.asp
Old Jun 1, 2007 | 06:47 AM
vzdude's Avatar
DTR's 'Go to Guy'
a complete wiring diagram Refer to Section 8W.
When Monitored:
At key on.
Set Condition:
The fuel pressure sensor reading at key on does not match the expected fuel pressure reading at key on.
Possible Causes
OTHER DTC'S PRESENT
FUEL RAIL PRESSURE SENSOR
FUEL SYSTEM TAMPERING
INTERMITTENT CONDITION
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 9 - ENGINE - DIAGNOSIS AND TESTING)
Diagnostic Test
1. OTHER DTC'S PRESENT
With the scan tool, read DTCs.
Are any DTC's present?
Yes
Repair other DTC's first.
Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL). (Refer to 8 - ELECTRICAL/ELECTRONIC CONTROL MODULES/ENGINE CONTROL MODULE - DIAGNOSIS AND TESTING)
No
Go To2
2. FUEL PRESSURE READING
Using the scan tool, monitor the actual fuel pressure reading while the key is on and engine is not running.
Is the actual fuel pressure reading greater than 870 psi?
Yes
Go To3
No
Refer to the INTERMITTENT CONDITION Symptom (Diagnostic Procedure). (Refer to 9 - ENGINE - DIAGNOSIS AND TESTING)
3. FUEL RAIL PRESSURE SENSOR
Visually inspect the fuel system components for signs of tampering, pay particular attention to the fuel pressure sensor on the fuel rail and the fuel pressure sensor wiring harness.
Were any signs of tampering discovered?
No
Replace the Fuel rail pressure sensor.
Yes
Restore Fuel system to original condition.
Old Jun 1, 2007 | 10:28 AM
dodgezilla04's Avatar
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Jun 1, 2007 | 10:29 AM
vzdude's Avatar
DTR's 'Go to Guy'
zilla.....191 isn't on that list for some reason.
Old Jun 1, 2007 | 10:35 AM
you're right.
mega, are there ANY fueling boxes or programmers installed on that truck?
i used to get that code when i was running an edge ez. it is from low rail pressure. went to a quad and no code.
some sensors are just barely within tolerance from the factory. there may be nothing wrong with your actual pressure, just the sensor is close to its lower tolerance range.
makes a difference if you have mods on the truck.
Old Jun 1, 2007 | 05:59 PM
Mike Perez's Avatar
PO191 Fuel Rail Pressure sensor Circuit Range/Performance
tomm
Dec 21, 2016 09:23 PM
runamuk
Dec 21, 2016 09:05 PM
ohioviper
Aug 14, 2008 09:45 PM
Crankpot
Aug 1, 2008 10:39 PM
ptgarcia
Jan 15, 2007 08:46 PM
