Changed fuel filter, something broke
Old Sep 14, 2008 | 12:44 PM
noworries's Avatar
I put the new fuel filter in, and I turned the truck over, the pump starts to run, but it's leaking fuel because the drain is stuck open. So I work the drain handle up and down a few times, which supposedly stops the leaking...
Now when I turn it over, the pump doesn't run.
Any ideas?
Old Sep 14, 2008 | 12:47 PM
mishkaya's Avatar
Sounds to me like you may have either blown a fuse, or somehow disconnected the harness to the lift pump. I would start first by checking fuses and relays under the hood, then make sure all connections are secure on the wiring harness in that vicinity. While the stock lift pumps are junk, they don't usually go in that manner.
mishkaya
Old Sep 14, 2008 | 12:54 PM
P.J's Avatar
P.J
You can just "bump" the starter to see what you have. In other words, you don't need to be cranking to hear the LP running. (if it is)
Old Sep 14, 2008 | 02:53 PM
noworries's Avatar
Yeah I was just bumping it. Is there a fuse for the lift pump? I just reconnected the connector on the front of the fuel filter, wiggled all the wires, and reseated the fuel relay I found in the fuse box under the hood. It seems to be running now.
Busier then hell right now so the last thing I needed was to get stuck replacing a lift pump today!
Thanks for the help guys!
209trucker
Sep 22, 2013 11:35 AM
Rue
Feb 2, 2009 02:43 PM
Bookshelf
May 14, 2008 11:05 PM
j-dubya
Sep 28, 2005 08:39 AM
KATOOM
Oct 22, 2004 11:33 PM
