Castor & camber angles
Old May 6, 2006 | 02:22 PM
the chef's Avatar
I have had 22" wheels fitted to my 2006 Dodge Ram 2500 diesel and a 3" lift on the front end. The front tyres are now wearing on the outer edges. Can anybody tell me what the Toe-in, Toe-out, castor & camber angles should be so i can get it set up properly. Many thanks
Old May 7, 2006 | 05:25 PM
RCW's Avatar
RCW
With the oversize wheels and a lift kit you need to retain the same degrees of castor and camber as OEM, but now measured at the new vehicle height. Most off road shops that have a frame and alignment rack will have the information already set up for their machine. However, you will need to set your toe-in to be neutral, then pull it in just enough so it will not wander. This may take a few tries, but it is the only way that works and does not scrub off the front tires.
Diesel_Power_2
Sep 21, 2011 07:05 PM
TrkEnvy
Jan 15, 2011 01:21 PM
megajoltman
Nov 11, 2008 08:18 AM
Holycack
Aug 26, 2008 12:22 PM
PourinDiesel
Apr 15, 2005 08:34 PM
