Carhauler now in denver
Old Apr 13, 2008 | 01:40 PM
dallascarhauler's Avatar
Cool Carhauler now in denver
I have a 2006 3500 that I use with a 53 foot wedge trailer to haul cars. The other day I cut my air on, and it blew out hot air then my temp shot up! then it would go to normal, and up again. I open the hood and felt the hose and it appeared the thermostat was faulty. I replaced, and the air still isnt working, and when I climb hills the temp shoots back up, but when I get to 6th gear it goes to normal. HELP
Old Apr 13, 2008 | 01:52 PM
J BODY's Avatar
Sounds like your electronic clutch fan has quit. It's too bad someone doesn't come up with a way to "pin" the fan so it is locked so you can at least keep moving. Sure the fuel economy would suffer, but sure beats getting stranded.
Old Apr 13, 2008 | 01:57 PM
Thanks J,
Will the fault codes show this?
Old Apr 13, 2008 | 02:39 PM
J BODY's Avatar
Might show up as a speed sensor error as that is what usually goes on them. Not much of a "test" on that fan, but it can be monitored with a DRB. I usually turn the a/c on and then monitor the fan duty cycle and the high side a/c psi. Once the psi goes up, the ecm will command the fan to go 95% duty cycle which at that point you can usually hear the fan start pulling air and the a/c psi will go down.
phox_mulder
May 29, 2004 10:19 AM
phox_mulder
19
Dec 24, 2003 02:22 AM
Commatoze
20
Sep 1, 2003 08:30 PM
BarryG
May 2, 2003 09:34 AM
