Broke Colum Wire
Old Nov 13, 2007 | 01:35 PM
RYANP's Avatar
Broke Colum Wire
Well, here is my first post.
Steering colum had a broken wire and the truck would only run with the steering wheel all the way down. I took it apart and found the broken wire. I sawdered (sp) it together. The sawder (sp) was too thick so I started to file it down. While doing this I ground out the wire when the file touched to colum - yes, I know I should have unhooked the battery but was lazy. Now there is no power in the wire and I can not find a blown fuse. (all the dash lights are out as well) I need this truck going.
2001 diesel
Thanks
Ryan P
Old Nov 13, 2007 | 01:48 PM
Foxborough's Avatar
I really can't help you but I'm sure someone could help if you could describe the wire location (under the steering wheel) and mostly the color coding. I have information only for an 06, sorry. I would guess you may have fried a module which might hurt a little.
Old Nov 13, 2007 | 02:00 PM
RYANP's Avatar
I hope I didn't fry a module. The wire is a red one that comes up to a 6 or 8 wire block under the ignition. The larger red wire in the bunch. Wouldn't a fuse blow before a module went?
Old Nov 13, 2007 | 03:03 PM
Foxborough's Avatar
I would hope a fuse would go first. Do not take this bad but did you make positive sure all fuses were not blown? I like to verify with a meter just to make sure. Search on the web for electrical schematic.
Old Nov 13, 2007 | 03:11 PM
RYANP's Avatar
I pulled every fuse that I could find and none were broke. I havn't delt with blown fuses very often though. I'm looking for one that the loop is broke in half on the 10 and 15 amp fuses. Could there be a small break and not one as lare as I'm looking for? How do I test with my meter?
Old Nov 13, 2007 | 03:20 PM
Foxborough's Avatar
Only thing I could find is a service manual from Geno's garage. Manual or CD about $100. http://www.genosgarage.com/products.asp?dept=17. An auto parts store may have a service manual with schematics. Sorry not much help..
Old Nov 13, 2007 | 06:24 PM
infidel's Avatar
Did you look in the underhood fuse box?
Most autoparts sell a cheap fuse tester that allows you to test the fuses without removing them. Many times you can't tell just by looking.
Old Nov 13, 2007 | 06:49 PM
Stormin_Norman's Avatar
Yes, and check the relays also.
Old Nov 13, 2007 | 08:30 PM
Busboy's Avatar
The wire you describe has to be from the #10 fuse in the under hood box. It's 50A, its the 4th one down on the second row labeled Ign/run accessory. The wiring schematics show that as the only large red wire with power going TO the ign sw.
Old Nov 14, 2007 | 07:45 AM
RYANP's Avatar
Problem solved. I hate to admit it, but I missed the blown fuse under the hood. I checked them like 3 times and still missed it. Dodge should have a recal on this problem - those wires are so tight under the colum and they are streching when you tilt the wheel down. I soldered it and drove a scerw in behind the wire conector so it doesn't come out again. I hope.
Old Nov 15, 2007 | 05:37 PM
I've had three break in my 02, turn signal, horn, and ignition .
MoparMarv
Aug 1, 2008 10:48 AM
Ramdaddy
Nov 9, 2007 12:35 PM
linetrash75
Aug 20, 2006 10:37 AM
billyrae
Sep 2, 2004 08:45 PM
TPilaske
16
Nov 22, 2002 08:15 PM
