Brakes locked up on 2001
Have 2001 dodge diesel ..pulling boat other day headed down bridge when I apply the brakes the passenger side front wheel locked up causing me to go into skid....skeered crap out of my buddy ....being foggy and not being able to see didint help things either..I have noticed that this happen only in wet conditions,,,ABout 3 months ago I replaced the caliper on the side that is locking up????? I have abs brakes only on the back brakes...Thanks for any help...This is a 2 wheel drive 3/4 ton truck..
Does the vehicle pull to one side or the other on dry road??? Could be a colapsed brake hose. Did you turn rotors and install new pads when you put on the caliper. Ive ran into problems with pads that have been heated up unequally and causing a pulling problem or locking up problem. Just my $.02
If it is a collapsed brake line you should be able to lift that wheel off the ground and mash the pedal down and see if that wheel remains hard to turn and if it does then open the bleeder on that calipar and if the wheel turns freely put a new hose on it.
Sometimes over time a off center crimp on a rubber brake line will get worse with time as rust corrision builds up and slowly closes off the line. Pressure will go into the calipar but it is hard for it to escape back.
