brakes are failing
Old Apr 8, 2010 | 10:52 AM
farmboyhull's Avatar
brakes are failing
i'm hoping someone may have a few quick suggestions.
the brakes work when i first press them, but my foot slowly sinks to the floor and the brakes decrease. the abs light comes on and the goes off. the parking brake light came on once as well.
any ideas?
thanks.
97 diesel 4x4 with 196k
Old Apr 8, 2010 | 11:31 AM
madhat's Avatar
Administrator/Jarhead
Could be air in the lines, bleed them for free, but it sounds like a master cylinder is taking a poo. Could also be a leaky caliper or wheel cylinder. (not too educated on 2nd gen brake systems, some of this info may be generalizations)
Have you inspected your brakes? What do they look like? Any signs of leaks, torn boots around the plungers? Pads worn?
Old Apr 8, 2010 | 12:10 PM
i haven't done anything. yesterday i had the bed loaded to the max with compost, today it's empty.
i just washed dishes for the senior lunch at the church. what a good doobie.
i was hoping that someone would be able to solve this, via internet, with one little easy fix. like, "tap your horn twice and that should solve it." well, at elast it's uphill getting home.
thanks.
Old Apr 8, 2010 | 12:13 PM
patdaly's Avatar
Hat hit it, if you are not losing fluid, the MC is likely toast ( cheapest bet ) Since you have good pedal at first, I don't think air is likely. Another slight possibility is the ABS dump valve next to the proportioning valve, but when mine was acting funny, it was like you had no brakes at all until you got the accumulator filled. I suppose the seat could be slowly leaking down though....
Old Apr 8, 2010 | 12:14 PM
patdaly's Avatar
Do you have 2WABS or 4WABS? Should say on the sticker under the hood.
Old Apr 9, 2010 | 07:40 AM
well, it became pretty obvious when i saw the giant puddle of brake fluid under the front right wheel!
as far as abs goes, it appears that i may not have it. when i bought the truck, used, everything was unplugged. there is a fuse and a relay missing, and a few connections are unplugged. i never really heard why.
i'm not sure this truck is going to last that much longer, anyway. the rust is advancing fairly steadily.
thanks for your help.
Old Apr 9, 2010 | 11:31 AM
patdaly's Avatar
LOL, Where are you located?
Many of us would rebuild the hull many times over before giving up our 12 valves.
97 happens to be a pretty good year for CTD's.
Old Apr 9, 2010 | 10:02 PM
grouch's Avatar
The puddle could be either a failing caliper or a leaky flex hose. Both are about due to fail. Since you have some pressure, I'd lean towards the caliper.
Old Apr 10, 2010 | 12:58 AM
madhat's Avatar
Use some brake parts cleaner and try to isolate where the leak is coming from.
It will not hurt to replace the lines, too.
killed300ex
Jul 20, 2007 02:49 PM
wildcargo
Nov 29, 2005 04:20 AM
Asher
Jul 19, 2005 01:36 PM
swansong04
14
Jun 11, 2005 12:02 AM
rattle_rattle
Sep 15, 2003 07:19 PM
