blue smoke and miss under load
Old Nov 17, 2005 | 06:57 PM
bbrfarm13's Avatar
Question blue smoke and miss under load
Drove to work this morning all fine 27 degrees out and snowing. Left work today warmed up truck outside temp was 21 degrees. temp gauge showed between 140 and 180 got out on road and when going over 1600 rpm or up hill it misses and smokes blue I put $30 of new fuel and a can of anti gel. got home 35 miles later by just babying it so did not miss. I am going to go out and try to drain water sep. but this was done 2500 miles ago when i changed the oil , ANy Ideas?
Old Nov 17, 2005 | 07:09 PM
mr T's Avatar
any codes? could be pump/lift pump (known 24 valve problem)....hope its not
Old Nov 17, 2005 | 11:13 PM
TORQUE's Avatar
Sounds like you could have got bad fuel with water in it. Add some more antigel, drain water separator. May have to change fuel filter again. Do you know if it is still summer fuel that you may have filled up with, and started problem? Change to different truck stop, or where you know they sell lots of fuel regularily. Did you notice if tanker was filling underground tanks while you were there? If this doesn't clear it up, check for codes, check fuel pressure, and check for fuel heater working properly, it's on side of fuel filter housing near the top.
Old Nov 18, 2005 | 06:27 PM
bbrfarm13's Avatar
Truck acted up this morning, but was great on way home got to run a few 3000 rpm stretches. I think this was a bad fuel problem as my son has used the truck this week and said the fuel he got was red in color, from his friends farm tank, this detail was told to me as he had to help me check the fuel pressure 13lbs idle to floor post filter port.and drian the water sep he was top and i held the cup to drain it into1 and 1 half ounce water in bottom of paper cup. want to change filter this weekend.
Old Nov 18, 2005 | 06:44 PM
AAmeeting's Avatar
Is the agricultural bad fuel for 24 valvers? Will it work in normal situations? I know it is illegal but so is 2.89 a gallon.
Old Nov 18, 2005 | 06:46 PM
99 cummins's Avatar
Ag fuel is the same as you get from the local truck stop, just doesn't have the taxes added to it so they color it different.
Forgot to add that this may be a summer blend fuel that was getting to cold these last few days. Unlikely but possible, it usually needs to be alot colder than this to affect fuel.
93-12Smoke
Jan 26, 2013 12:49 AM
John D
Jun 7, 2011 09:52 AM
Diesel_Power_2
Dec 6, 2010 06:29 PM
Benjamin b2
Oct 14, 2009 07:15 PM
cberndt454
Sep 28, 2005 03:39 AM
