Big 12 point bolts on caliper?
Old Aug 14, 2004 | 11:35 PM
blh4645's Avatar
Do I have to remove these big bolts to change front brake pads on a 2002 2500 4x4 old body style? Or just remove the two small allen wrench bolts completely and pry the pads away from the rotor? don't want to mess anything up.
Old Aug 14, 2004 | 11:43 PM
DODGE4X4's Avatar
Just take off the 2 bolts that hold on the caliper.
Old Aug 15, 2004 | 07:42 AM
amartinson's Avatar
You can leave the caliper mounting bracket (12 point bolts) if you are not going to remove the rotor. But on my '01, the caliper is held on with TORX bolts, NOT ALLEN, so make sure you are using the correct tool for caliper bolt removal.
Old Aug 15, 2004 | 09:13 AM
hotdram's Avatar
Same here, on my '02, the bolts are Torx. I forgot what size.
~Rob
Old Aug 15, 2004 | 03:01 PM
blh4645's Avatar
Thanks for your help guys. I got them done with no problems. torx bit size was T40. They were diffently different than any other brake pads I've changed in the past.
zgoober
Oct 21, 2010 10:13 AM
grishfish
Aug 23, 2009 09:54 PM
bngcustoms
Jul 17, 2009 04:53 PM
1985cucv
Mar 17, 2009 09:06 PM
JKM
Oct 24, 2006 07:43 PM
